Prodajem navedeno pojcalo,pojacalo je NOVO bez ijedne packe,kod mene sviralo 5 minuta,a kod prethodnog vlasnika max 5 sati sveukupno.
Evo specifikacije:
Features:
* 1 x 1750 RMS @ 1 OHM
* 1 x 3500 watts peak @ 1 ohm
* 1 x 1750 watts peak @ 2 ohms
* Top of the line Components
* Heat Management System
* Built in sub-sonic filter
* High Efficiency Mosfet Power Outputs
* True 1 ohm stability (other brands write 1 ohm, but when you run them at 1 ohm the amp smokes. these are true 1 ohm stable!)
* Built in Low Pass CrossOver - adjustable at 12 dB per octave
* Bass Remote Control
* Class A/B
* frequency response: 20-250 KHz
* THD: .05 %
* S/N Ratio: Greater than 95 dB
* Input voltage: 11 - 14.4 volts
* Adjustable Input sensitivity: .2 MV - 5V
* bass boost control @ 45 hz - 12 dB
* dimensions: 12.6" x 2" x 10.9" inches
Slike
http://www.audiodiscounters.com/shopping/image.php?type=D&id=272?1292961546052
CIJENA:200KM
Zamjena:Moze za Sound Magnus da nije popravljan i slicno.
Evo specifikacije:
Features:
* Class A/B
* THD: .05 %
Slike
CIJENA:200KM
