P: navedeno pojačalo kenwood KAC-9152D
Class D Amplifier Yes
Load Capability 1Ω Stable
Maximum Output Power 1800W
Rated Power Output 500W x 1 (4Ω)
Rated Power Output 900W x 1 (1Ω)
Low-pass Filter Yes
Bass Boost Circuit Yes
Infrasonic filter Yes
Phase inverter 0°(Normal) / 180°(Reverse) Yes
Dual Mono Drive Capability Yes
Power Indicator Multifunctional
Line in 1 RCA (Gold Plated)
Line out 1 RCA (Gold Plated)
Speaker level Input Yes
Removable Coverplate Yes
Yes
DC cable Supplied No
Amplifier-Specifications
Maximum Power Output (4Ω) 1800W x 1
Rated Power Output (4Ω, 14,4V) 500W x 1 (20Hz ~ 200Hz, 0.5%THD)
Rated Power Output (2Ω, 14,4V) 900W x 1 (100Hz, 0.9%THD)
Rated Power Output (1Ω, 14,4V) 900W x 1 (100Hz, 1%THD)
Low-pass Filter 50~200Hz (24dB/oct)(B-Channel)
Bass Boost Circuit 0~18dB/oct
Bass Boost Frequency 40Hz ~ 100Hz (Variable)
Infrasonic filter 15/25Hz (18dB/oct)
Input Sensitivity 0.2 ~ 5V
Input Impedance 10kΩ
Signal to Noise Ratio 96dB
Frequency response (+0dB, -3dB) 5Hz ~ 200Hz
Operating voltage 14.4V (11V ~ 16V allowable)
Maximum current consumption 60A
Installation Size (WxHxD) 380 x 61 x 286 (mm)
Weight 5.8kg
CIJENA: 200KM
![kac9152d.jpg](http://img177.imageshack.us/img177/9052/kac9152d.jpg)
Low-pass Filter Yes
Yes
Weight 5.8kg
CIJENA: 200KM
