Principle 3 way triax system
Power Handling 80 / 320 watts
Impedance 4 ohms
Frequency response 30-21.000 Hz
Crossover Frequencies 3000 / 6000 Hz
Sound pressure level 91 dB
DIN-Diameter 200 mm (8") woofer
50 mm (2") midrange
13 mm (0.5") tweeter
Outer diameter 220 mm
Cutting Out 184 mm
Mounting depth 80 mm
Mouting height 21 mm
Cone material Woofer: coated cellulose
Tweeter/midrange: Polycarbonate
Highlights
Warp resistant, low-resonance steel basket
Embossed polypropylene cone for less distortion listening
Additional voice-coil ventilation for better power handling and less mechanical damping
Tweeter with acoustic equalizer and neodymium drive
Designer loudspeaker covers with optically integrated tweeter flange
Zvucnici su novi cijena: 110 Km
Impedance 4 ohms
50 mm (2") midrange
Cutting Out 184 mm
Highlights
