znaci woofer kenwood u dobrom stanju i pojaca Kenwood KDC-6403
500 Watts max power (4 ohms bridged)
60 Watts x 4 (2 ohms) RMS
40 Watts x 4 (4 ohms) RMS
Aluminium die-cast heat sink
Built-in low-pass filter 80Hz (12dB/oct) on B channel
Built-in high-pass filter 80Hz (12dB/oct) on A channel
Input sensitivity 0.5 - 5.0V variable
Frequency response 10 - 50,000 Hz
Signal to noise ratio < 100dB
Maximum current consumption 21 A
2 ohm load capability
Speaker level input or RCA line outputs
Power MOSFET switching power supply
Red LED power indicator
Dimensions (WxHxD) : 330 x 60 x 230 mm
sa kutijom
http://img231.imageshack.us/img231/3816/27722598.jpg
evo slika woofera i kutije.
cjena je 190 km.
za kes se mozemo dogovorit oko cjene.
zamjene nista samo kes
sa kutijom
cjena je 190 km.
