JBL W12 GTI :'( :'( :'(
Zbog promjene planova i pokretanja drugog projekta
Subovi su u odličnom stanju,kod mene svirali svega 3 dana i od tada čekaju :'(
cijena po komadu 200eur,a ima se 2 kom
Mob:091 728 45 27
specifikacije:
12" GTi Differential Drive® Design Subwoofer
Dual Voice coil design (dual 6-ohm, pre-wired as a 3-ohm sub)
Differential Drive® Design (DDD) motor
Die-cast vented basket
Kevlar-impregnated paper woofer cone
Nitrile-butylene surround
Power handling RMS: 700 watts
Power handling Peak: 4,000 watts
Sensitivity 91dB @ 2.83V/1m
Power Handling 700W RMS, 4,000W Peak
Frequency Response 18Hz ~ 1kHz
Impedance 3 or 12 ohms
Voice-Coil Diameter 3" (76mm)
Mounting Depth 10-1/4" (260mm)
Overall Diameter 12-1/4" (312mm)
Cut-Out Diameter 11" (280mm)
Displacement 0.149 ft3 (4.23 l)
evo dobio info od kolege
ZR 1.09
Zvone Raspor 1 mjesec 2009 - popravljano!!!
http://www.zr-speakerlab.si/
Na wooferima se ne vidi da je nešto rađeno
slika sa DD 9515 radi usporedbe
Mob:091 728 45 27
specifikacije:
ZR 1.09
