Na prodaju dato pojacalo akcijska cijena NOVO ne Koristeno nakupilo prasinu na policama
Cijena 799EUR ovaj ide za 500Eur, moguca dostava po BiH ..
specs
BRUTUS B3 monoblocks are the ideal companions to the analog Zeus amplifiers in the same cosmetic design. With their thought-through features like Phase-Shift (0-180 °), variable Q-control and bass-boost (20-80 Hz) as well as the 1 ohm stability, they are ideal for subwoofer application. The powerful Class-D technology enables the amps to achieve high efficiency (up to 80%), they deliver lots of power but keep the electrical system in your car unburdened.
• Advanced Class-D Digital Technology
• New Class-D Chipset with high Damping Factor
• Bass Remote Controller
• Screw-type RCA In-/Output Jacks
• Molded Terminals & Maxi-Fuses
• Illuminated, switchable Logo Badge (blue/white)
• Aluminum Endpanel Frames & Controller Knobs
• Double-sided PC-Board with reinforced Copper Trays
• Lowpassfilter 35 - 250 Hz, Subsonicfilter 15 - 55 Hz
• Master/Slave-Mode with Protect Bridge,
• Extended Bass Control: Bass EQ, Freq. and Q-Factor sep. adjustable
• Phase Shift 0° - 180°
• Balanced Line-Inputs
BXi6000D
Ultra Class D Digital Monoblock
1 x 1200/2200/3000 Watt RMS @ 4/2/1 Ohm
260 x 60 x 500/530 mm
evo test njegovog manjeg brata iz njamackih novina...
http://audiodesign.de/downloads/testberichte2008/ZXi2201-BXi4000D.pdf
specs
BXi6000D
