P: DLS sub 10" 40€
P: DLS sub 10" 40€
Pojacalo PRODATO
Ostao vufer
Specification
* Weight : 5,3 kg (11,68 lb)
* Impedance : 4 ohm
* Woofer size : 10" (25 cm)
* Power handling capacity : 200 W RMS
* Max power handling capacity : 400 W
* Peak power : 600 W
* Frequency range : 20-1000 Hz
* Sensitivity : 91 dB (1W/1m)
* Magnet size : 145 mm (5,7"), 80 oz
* Outer diameter of woofer : 262 mm (10,31")
* Mounting depth : 129 mm ( 5,08")
* Mounting hole : 232 mm (9,13")
* X-max : +- 9 mm (0,35")
* T/S parameters
single V/C:
odlicno stanje, bez mana i ostecenja. ..
Cijena: 50e
+381 65 538 79 56
ja sam radio ovu kutiju i kutija je sama bila 25 eura tako da je ovo prakticno DZABA!!!
