Prodajem auto pojacalo monoblock, novo, specifikacije su slijedece:
* 1 x 1750 RMS @ 1 OHM
* 1 x 3500 watts peak @ 1 ohm
* 1 x 1750 watts peak @ 2 ohms
* Top of the line Components
* Heat Management System
* Built in sub-sonic filter
* High Efficiency Mosfet Power Outputs
* True 1 ohm stability (other brands write 1 ohm, but when you run them at 1 ohm the amp smokes. these are true 1 ohm stable!)
* Built in Low Pass CrossOver - adjustable at 12 dB per octave
* Bass Remote Control
* Class D
* frequency response: 20-250 KHz
* THD: .05 %
* S/N Ratio: Greater than 95 dB
* Input voltage: 11 - 14.4 volts
* Adjustable Input sensitivity: .2 MV - 5V
* bass boost control @ 45 hz - 12 dB
* dimensions: 12.6" x 2" x 10.9" inche's
Cijena po dogovoru
Za detaljnije informacije zovite na broj: 061-310-548
[attachment=35526][attachment=35527][attachment=35528][attachment=35529]
* Class D
* THD: .05 %
Cijena po dogovoru
