Subwoofer ALPINE HIGH END TOP MODEL
kao nov, nikad przen slusan u kompresiji od kad je kupljen - cijena 300 EUR a u kompletu sa mrd-m1005 oboje za 500 eur
* Designed and Engineered in the USA
* Hidden Screw Gasket
* Gold Plated Insert Terminal Block with VC Connection Jumpers
* One-Sided Terminal Layout
* Massive Triple Stacked Strontium Magnets
* FEA Optimized High Excursion Injected Santoprene® Multi-Roll Surround
* FEA Optimized Mirrored Progressive Nomex® Spiders with Integrated Tinsel Leads
* FEA Optimized CRC T-Drive Motor Structure with Copper Shorting Sleeve & Heat Transfer Technology
* Multi-Stage Ventilation System (Dual Flare Pole, Spider Plateau & Frame Leg Venting, Cone/VC Junction Venting)
* Integrated Spider Landing and Heat Transfer Plate
* Dual Voice Coil Design, 4-Layer 220°C High Temp Wire with Inner/Outer Winding on Twin-Wall Brass Former
* Custom Cast Aluminum Frame
* Carbon Fiber/Aluminum Honeycomb Parabolic Cone
Power Specifications
* 3000 Watt Peak Power
* 1000 Watt RMS Power
* Impedance: 4+4 Ohm
* Sensitivity 86dB/W (1m)
* Frequency response: 20-500Hz
* Mounting depth: 221 mm
* Cut-out diameter: 277 mm
