Nije popravljano koliko ja vidim, ima nekih sitnih ogrebotina, al ništa strašno :respect:
# 700W x 1 RMS (4ohm, 14.4V, 1% THD+N)
# 1.000W x 1 RMS (2ohm, 14.4V, 1% THD+N)
# Max. 1.800W x 1
# S/N Ratio 90dBA
# Internal, variable-speed cooling fan
# Amp Link for single-cable hookup to compatible Alpine receivers
# STAR Topology for cleaner sound
# Bass Engine® features:
* Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
* Selectable subsonic filter (off, 15Hz, or 30 Hz)
* Parametric EQ variable from 30-160 Hz, ±12 dB
* Bass Compensator enhances low-end definition
# Top-mounted digital control center with cover
# CEA-2006 Compliant
# MOSFET power supply and output stages
# Preamp outputs
# Time correction 0-10 milliseconds in 0.1ms steps
# Phase adjustment 0-180
# Turn-on delay
# Requires 4-gauge power and ground leads and 80 amp fuse
# Extra-large terminals
# Fuse rating: 20A x 4
# Dimensions: 13"W x 2-5/16"H x 8-11/16"D
Slike:
Cijena 210€, zamjene za svašta zanimljivo
# Max. 1.800W x 1
# S/N Ratio 90dBA
# Preamp outputs
# Turn-on delay
Slike:
