Amp ima super opremljenost,display koji pokazuje voltazu,temperaturu,rezove skretnice,visinu gaina,skretnice imaju hi-lopass za svaki kanal,dakle aktiva se slozi s lakocom! Ventovi se termalnim senzorom(dakle pale se samo po potrebi),mogucnost spajanja sa Alpine headunitima putem Amplifier linka,i upravljanja opcijama pojacala na headunitu... Ampovi su jako UNDERRATEANI!
Idealno za pogoniti neki 2+1 system , sa 2x 110W na prednjim kanalima i 350W u mostu za subwoofer...
# 4-channel car amplifier
# 75 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
# 300 watts RMS x 1 (channels 3/4 only) in bridged mode
# Amp Link allows single cable connection for signal and control with compatible Alpine receivers
# 2-, 3-, or 4-channel output
# CEA-2006 compliant
# Tri-way capable (Tri-Way crossover required)
# variable low- and high-pass digital filters, 30-400 Hz or 600-8000 Hz at 12 dB/octave
# bass boost (0-16 dB in 2 dB steps, centered at 45 Hz)
# MOSFET power supply
# STAR Topology (minimizes internal noise and prevents ground interference)
# preamp-level inputs and outputs
# oversized power and ground connections with gold-plated screw terminals
# top mounted controls with cover
# detachable front cover
# blue power LED
# requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
# dimensions: 13"W x 2-7/16"H x 9"D
U Autohifi casopisu za mrv-f 345 je izmjereno 4x110RMS-a na 14.4v!!!!!! RMSa.
CIJENA 400KM BEZ ZAMJENA!!!
# blue power LED
