-prodajem dva woofera u jednoj kutiji orginal sve...RANKFREAK marka
neznam specifikacije znam samo da grme![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i ima one neonke oko membrana koje svijetle kad se upali...
ako ko zna neka posalje evo slike
-pojacalo mac audio MPX 4000
http://www.google.ba/images?hl=hr&q=mac+audio+mpx+4000&um=1&ie=UTF-8&source=univ&ei=qOlaTJf-NqOWOOv93d0N&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CDQQsAQwAw&biw=1280&bih=645
Max. power output* into 4 © 4x180 / 2x500 Watt
RMS power output** into 4 © 4x60 / 2x160 Watt
Max. power output* into 2 © 4x250 Watt
RMS power output** into 2 © 4x80 Watt
Frequency response 5 – 50 kHz (-3 dB)
THD 100 dB
Input sensitivity 0,4 – 4 V
Dimensions (W x L x D) 319 x 59 x 226 mm
Input impedance 20 kOhm
Power impedance 12 V minus an Masse
Weight 2,65 kg
-Pojacalo MAGNAT classic 360
http://www.google.ba/images?hl=hr&q=magnat+classic+360&um=1&ie=UTF-8&source=univ&ei=GOlaTKCVBpiUOJyuwNcN&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CC8QsAQwAw&biw=1280&bih=645
4 x 90wrms @ 4 ohms
2 x 180wrms @ 4 ohms bridged
2 x 90wrms @ 4ohms + 1 x 180wrms @ 4ohms
Freq. Response: 5Hz ~ 50kHz
Fuse: 2 x 25A
Dimensions: 15.8" x 10" x 2.1" (40.2cm x 25.4cm x 5.4cm)
Weight: 10 lbs. (4.5 kg.)
adjustable low pass filter @50 or @80 or fullrange.
sve ukupno 400 KM...pojedinacno na upit
![image0333.jpg](http://img576.imageshack.us/img576/1070/image0333.jpg)
THD 100 dB
Weight 2,65 kg
4 x 90wrms @ 4 ohms
Fuse: 2 x 25A
