Blaupunkt pojačalo i Rora
Prodajem Blaupunkt pojačalo GTA 460
* Max. Power (Watt): 800
* Number of channels : 4 Channel
* Stability normal mode (Ohm): 2
* Frequency response (Hz) -1dB: 10-30000
* Signal-/noise ratio at nominal power (dB): >90
* Distortion factor at nominal power (1 kHz): <0,05
* Type: Analogue
* Pre-equipped for Plug & Play: No
Inputs
* Max. cable diameter (mm²): 10
* Ignition supply: Yes
Outputs
* Loud speaker (connection type): Screw
* Loud speaker (number of): 4
* Loud speaker (max. cable diameter in mm²): 6
* Connector material: Silver
General
* Height x Width x Depth (mm): 52x197x426
Product Features
Amplifier
Type: Analogue
Max. Power 4 Channel @4 Ohm (Watt): 4x120
Max. Power 2 Channel @4 Ohm (Watt): 2x400
Max. Power 4 Channel @2 Ohm (Watt): 4x180
RMS Power 4 Channel @4 Ohm (Watt): 4x60
RMS Power 2 Channel @4 Ohm (Watt): 2x180
Attenuation factor at 4 Ohm: >100
Input impedance (kOhm): >10
Input sensitvity (V): 0,1-8
High-pass filter crossover frequency (Hz): 80
High-pass filter edge steepness (dB/Octave): 12
Low-pass filter crossover frequency (Hz): 50-250
Low-pass filter edge steepness (dB/Octave): 12
Bass Boost setting range (dB): 0-12
LED for protect-mode: Yes
Inputs
Permanent supply: Yes
Ground: Yes
Surface connector: Silver
Outputs
General
Blaupunkt Rora
GTT 1200
# System Subwoofer tube
# Diameter (mm) 300
# RMS Power 200 Watts
# Max. Power 600 Watts
# Sensitivity 2.83 V/m 91 dB
# Frequency range Hz 35 – 500 Hz
# Impedance 4 ohms
# Cone material Spun Paper
# Installation depth (mm) 484 mm x 328 mm Ø
# Bassreflex Subwoofer tube
# Diameter (woofer) 300 mm (12")
Ovo dvoje 250KM
trenutno nemam slike ali ako nekog zanima stavit ću ih
može zamjena za neki mob.
ili šta ponudite
BI xenon
Gewinde
Player
sve me zanima
koliko je samo rora? i kakav ti mob.odgovara samo za roru..ja imam iphone mini kopiju nov full pakovanje..i samsung f480 kopija takodjer nov i full pack :D
Sahman_Turbe je napisao(la):
ja bih ako može sve u kompletu
a kopija mi se ne uzima =)
